Eric1361
Dec 11, 2021Aspirant
PS remote play - cannot connect to my PS5 outside of home
Hello, Can you please adivse how can I connect to my PS5 and desktop computer outside of home? It seems I need to do something on my router setting. Whenever I was trying to connect to my PS5 f...
michaelkenward
Dec 12, 2021Guru - Experienced User
What does that mean? I
f the PS5 and desktop computer are away from your home network, then you won't be able to use your Internet connection unless it is on a mobile network.
What Netgear hardware do you own?
What are you trying to do?
What are you doing and where does it go wrong?
Eric1361
Dec 12, 2021Aspirant
Hello, thank you for looking into this.
nighthawk AX6000 WiFi Cable Modem Router (CAX80)
I want to play ps remote play when I'm outside home through my ps5 in my livingroom.
I think my netgear cable modem router is blocking connection from outside of home.
In order to connect to my ps5 for remoteplay, I think I need to adjust setting so I can connect to my devices at home from anywhere.
