kirrond
Jan 28, 2026Follower
PS4 -> PS5 remote play detected as DOS
Since about a month I have issue with PlayStation RemotPlay connection over LAN network. The communication on port 9308 is established correctly, but then PS5 try to connect with PS4 on random port f...
Jan 28, 2026Guru - Experienced User
Is there Protection engine seen on the routers web page maybe?
If uPnP is enabled then yes, the first PS connected will pick up 9308. The 2nd PC connected will get a virtual port since two devices can not share same port number.
