lin9406's avatar
lin9406
Follower
Mar 17, 2021
QoS function of RAX20 does not work
The QoS function on the RAX20 is broken, whenever I tried to set the poriority in the QoS page, it always just go back to defult after the loading. I have a recording:
https://youtu.be/hrqh-1scJeY
I have two RAX20, both are doing the same thing. I tried resetting and rebooting countless times. The support chat was useless. Both routers are on the lastest firmware. This is so frustrating, a router costs more than a hundreds and one of the most important function just does not work at all
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
