bl1085
Nov 04, 2023Guide
QOS issues on Nighthawk RAX80 using VOIP
So I have a RAX80 Nighthawk router. On the Qos screen I see download speed of 90 Mbps, and upload of 12 Mbps (Xfinity Comcast) I have an Ooma VOIP box. I have the Ooma device set to "Prio...
Nov 04, 2023Guru - Experienced User
What modem/gateway do you have from xfinity?
Everyone sounds fine to you? but you don't to them?
I'd be curious about the upstream side of it then as your downloading fine.
An easy check would be to disable QOS and the wifi (if the ooma is hardwired) and just use it hardwired with nothing else attached. That leave the ooma the only thing running and QOS can'ts low it down or other devices. If that fixes the issue, its qos related/speed related. If you still have the issue, then it isn't the router causing it. It'd either be the modem, ISP speeds you pay for, or the ooma.
