bl1085
Nov 04, 2023Guide
QOS issues on Nighthawk RAX80 using VOIP
So I have a RAX80 Nighthawk router. On the Qos screen I see download speed of 90 Mbps, and upload of 12 Mbps (Xfinity Comcast) I have an Ooma VOIP box. I have the Ooma device set to "Prio...
bl1085
Nov 04, 2023Guide
Thank you for the 2 answers posted.
My Comcast web page shows
"Download speed: up to 75 Mbps, Upload speed: up to 10 Mbps"
so it appears I am getting slightly better speed than I am paying for.
the cable modem is a Netgear CM2000 - same NightHawk series as the router.
Only question I don't see answered is why the "attached devices" list shows the Ooma as low priority when I explicitly defined it as highest priority???
I will try as suggested and turn off Qos and see if better.
Ben
- michaelkenwardNov 04, 2023Guru - Experienced User
That's pretty normal. Most ISPs deliver slightly over the specified speed.
Your speeds are not that fast. But I have the same sort of service (VDSL). I don't use VoIP but have never had any problem with on-line meetings, Teams, Skype and so on. And they need more bandwidth than voice.
"Attached devices" is one of those features that causes constant problems. It is often inaccurate and can miss things.
Suck it and see is an obvious thing to try. It can't do any harm. If that gets you nowhere, then follow the suggestions from plemans
