scottmmwood
Oct 25, 2022Aspirant
QoS on RAXE500 causes network dropouts
As the title said using a RAXE500 with QoS and downloading applications causes the network to that device drop out. this is using the latest firmware on windows 11 over ethernet with a 900mbps do...
- Oct 25, 2022
Why are you using QoS?
As the title said using a RAXE500 with QoS and downloading applications causes the network to that device drop out.The speeds you quote – if they are what your ISP delivers – are well above the levels of around ~200 Mbps where QoS is useful.
If anything QoS could slow you down as the router's processors does its stuff.
QoS is for old services where you had to fight to get games to run fast enough.
Have your turned it off to see if the problem goes away?
michaelkenward
Oct 25, 2022Guru - Experienced User
- scottmmwoodOct 25, 2022Aspirant
Yeah that looks like it sorts the issue.
I assumed QoS was good to have on.
Its new to me but this seems to be the fix.
Thank you!
- FURRYe38Oct 25, 2022Guru - Experienced User
Ya I would not use QoS and mentioned, it's mostly for low speed ISP services. Which most todays ISP and users are using the most. Not a lot of need for QoS up here at this speeds.
You'll be fine running with out it.
If your ISP modem or ONT connects at 1000Mpbs, then keep the 1Gb WAN port running on the RAXE. No need to use the 2.5Gb port. You can connect up a PC to this port if you have a PC that you may have a 2.5Gb ethernet adapter installed. I have one installed on my PC. Connects to the 2.5Gb port on the RAXE. Works great.
Enjoy. 📡 - michaelkenwardOct 25, 2022Guru - Experienced User
Nah, its a VDSL tool.
Enjoy that speed. If not the BT Box. I've had three different flavours over the years. Thankfully, the latest is just for the set top box stuff.
Still crap and I have to use a Firestick to get some services. (I don't own a TV.)
- michaelkenwardOct 26, 2022Guru - Experienced User
The label doesn't help. Who wouldn't want "quality"?
But, as you found, that isn't always what you get.
"Turn of QoS" is a regular refrain around here.
