LSXV258
Dec 10, 2021Follower
QoS priority assignments not working AX5200
When I go to change the priority in QoS, none of the changes get reflected and stay the same as they were from the start, i.e. changing the High to Normal and another Normal to High. The UI on the ro...
Dec 10, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
