jesseinla
Jan 17, 2023Aspirant
QoS Question
I notice when I enable QoS and only I am connected, my speed then lowers from 582Mbps to about 450Mbps. Is the QoS on my RAXE500 — Nighthawk AX12 12-Stream AXE11000 Tri-Band WiFi 6E Router not that i...
Kitsap
Jan 17, 2023Master
jesseinla wrote:I notice when I enable QoS and only I am connected, my speed then lowers from 582Mbps to about 450Mbps. Is the QoS on my RAXE500 — Nighthawk AX12 12-Stream AXE11000 Tri-Band WiFi 6E Router not that intelligent? Also, I noticed when I disable QoS my Ping goes down a few ms. This makes me not want to use QoS. Are they going to improve this in a future Firmware update?
When internet throughput capacities moved past the 200-300 Mbps range, QoS became obsolete. Turn it off and leave it off.
