lianmengwa
Dec 03, 2019Aspirant
Question about Changing Remote Management Address
Guys, I got a Question about changing Remote Management Address I got Nighthawk Rax120 and when I trying to change the remote management setting I got a problem. The problem is I use Nighthawk R...
lianmengwa
Dec 11, 2019Aspirant
First of all ~ thank you for your reply.i called customer service and they tell me this (what I said )is actually a BUG that he reported already and send it to evaluation team.
I need to setup as full-function router, instead of as a wireless access point because that I wanna manage wireless user with netgear router. And this is a router about 500 bucks. I don’t need an 500 dollars Ap . Right? lol
The address is locked means locked on rax120. The “public address “ (which is actually my main router’s address ) is used for web access and not changeable . So if I wanna access the router through 73.167.XXX.XXX: 8800 is automatically blocked by router. I could only access the web access through address. 192.168.1.204:8800 .
And yes my port forwarding setup has not problem. Main router 8800 port forwarding to rax120 8800 port.
antinode
Dec 11, 2019Guru
> [...] The address is locked means locked on rax120. [...]
I don't know what that means. I'll try again:
> [...] Did you reserve that address for it in the DHCP
> server in your (unspecified) "my main router"? Or configure the RAX120
> WAN/Internet interface with a static address? Or what?
> [...] if I wanna access the router through 73.167.XXX.XXX: 8800 is
> automatically blocked by router. [...]
"automatically blocked by" _which_ "router"? Your (unspecified) "my
main router" would need a port-forwarding rule to allow an incoming
connection from the outside world to get to your RAX120 at
"192.168.1.204:8800".
> And yes my port forwarding setup has not problem. [...]
It's nice that you're happy with it, but I can't see it from here.
> [...] i called customer service and they tell me this (what I said )is
> actually a BUG [...]
_What_ is the bug?
> [...] I could only access the web access through address.
Previous questions still unanswered:
> How, exactly, did you try to "access the router"? Actual URL?
> From where?
Also, what is the actual error message which you get when you try?
If you can access your RAX120 at "192.168.1.204:8800" from a system
on the LAN of your (unspecified) "my main router", and if the port
forwarding were working properly on that (unspecified) "my main router",
then it's hard to see how you could fail to access it from the outside
world. And it's even harder to see how a bug in the RAX120 could make
it fail.
Does the WAN/Internet address of your (unspecified) "my main router"
match your public address ("73.167.XXX.XXX")? Can you verify that its
port forwarding works with any other device?
- lianmengwaDec 13, 2019Aspirant
Rax120 WAN got a IP address from my main router.
Main Router got a “no-ip ” service. And I host web server and a NAS server connected directly to main router. And port forwarding works just fine with all both server computer . I host many websites myself so I know exactly how port forwarding work.
Automatic block by router which means automatically block by RAX120 . Rax120 will block any address access from WAN port other than the address shown on it. (Please check out the picture. )
The address on the picture is not changeable .it’s locked means I can’t not change this address. The router will block any access from WAN port other than this address . Means if the address is your public address even you forwarded the port already. It will not work. Because it will block by router (RAX120 ) . If Rax120 is the 1st. Lvl router this will not be a problem. Because the address locked to your public address and it will be fine. If you use it as 2nd lvl router. This became a real problem.- lianmengwaDec 13, 2019Aspirant
