Sharkman000
Aug 04, 2021Aspirant
Question About Netgear AX6 RAX45?
Greetings to all. I am a newbie here seeking assistance.
I changed the SSID of my guest network, and hours later it reverts back to its original SSID of ( Netgear 80 Guest )....even though when I changed it, i made sure to SAVE it, prior to logging out.
1 Reply
Tried again to confrm this behaviour?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your RAX45 hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
