HKSoft's avatar
HKSoft
Question about NETGEAR RAX120, need an expert for this question.
1. If I have 2 of NETGEAR RAX120, one for the AP mode and another one for the bridge mode on the 5Ghz band. Can it benefit from 8 streams and Beamforming from 8 of its antennas on both routers?
2. If it has 8 streams on a single 5Ghz band, why it can't reach the speed of 9.6Gbps?
  • plemans's avatar
    8 streams: 4x-2.4ghz streams (1.2gbps)  and 4x 5ghz streams (4.8gbps). Equals 6gbps. AX6000
    Not sure what you mean by 2x rax120s with one for ap mode and one for bridge mode. Is one of them running in router mode or are you using a different device for that.
    Not sure why you want to use bridge mode. you'd be much better off hardwired together.
    • HKSoft's avatar
      HKSoft
      Sorry to make you confused but NETGEAR RAX120 has 12 streams in total, 4 on 2.4Ghz and 8 on a single 5Ghz band.
      All questions I asked here focus on the 8 streams on the single 5Ghz band.
      Wire not an option for me, if I can wire my network I won't ask, obviously.
      • plemans's avatar
        sorry, it is 5ghz 8x8 but its still 4800mbps (4.8gbps)
