HKSoft
Mar 26, 2020Aspirant
Question about NETGEAR RAX120, need an expert for this question.
1. If I have 2 of NETGEAR RAX120, one for the AP mode and another one for the bridge mode on the 5Ghz band. Can it benefit from 8 streams and Beamforming from 8 of its antennas on both routers? 2. I...
HKSoft
1. My obstacle is 2 concert walls, 1 glass door, and 1 closet. The range is around 10 meters. It's between the same floor, indoor usage.
2. Now that you point it out, 360 Mbps its actual speed. Let me correct my mistake. On my current setup, I have connection speed between the router about 702 Mbps. So, the ratio should be 0.54. If I apply this to 4.8Gbps AX it should be 2,592 Mbps, the actual speed would be 1,296 Mbps. I aim to get the actual speed at least 1Gbps or more as a buffer.
3. I use powerline a few years ago before I move to the WIFI bridge. At first, it was fine but we change some of the electrical grid in our home after that it doesn't work anymore. Plus, I just get a gigabit connection that why I aim at 1 Gbps connection, which powerline can't deliver.
MoCA can't get 1 Gbps as far as I know.
Point to Point (I assume it an outdoor system?) required too much setup (drilling for the antenna) and besides that, I use it indoor across the 2 rooms on the same floor. And the speed of Point to Point is slow, and it expensive.
Mar 26, 2020Guru - Experienced User
Theoretically you'll see in improvement.
In usage? I'm not sure if it'll be that benefical. The concrete walls are the issue and 5ghz is sensitive to concrete as you've found out. With as fast as 5ghz AX speeds drop off, I'm not sure you'll see the same ration that you're seeing with the AC devices.
If you're not renting, it might be worth investing the time/energy/cost to find a way to run an ethernet cable. Otherwise it'll be a constant battle.
Not that I'm trying to stop you from buying a router but an RAX120 is currently $400 on amazon so $800 total for 2. I'd be willing to bet someone in your area would be willing to do the work for cheaper than that. Plus then you could just hardwire in your current devices
- HKSoftMar 26, 2020Aspirant
I wish I could wire... you could say my case is one of a kind. That why I struggle to find information. Back then when I plan to get the current WIFI bridge setup I bet the outcome but it worth it because the internet speed it uses to be like 200 Mbps.
But now I have a baseline for the WIFI bridge and I get 701 Mbps out of 1300 Mbps on my current router (3 streams). In theory, I should get the same or better ratio if I move to 4 streams AX with Beamforming, 160 Mhz bandwidth, QAM 1024, right? đ
Hopefully, when the router gets sales, I'll grab 2 of Nighthawk AX8 or ASUS RT-AX88U.
Which one do you think it the best between Nighthawk AX8 or ASUS RT-AX88U?
- plemansMar 27, 2020Guru - Experienced User
I don't have either one so can't attest to how well either one runs
