Dcm
Apr 04, 2021Aspirant
question on router speed
I Have a device tha need to run on 2.4 GHZ wifi how do I determine whatv the speed is Danon my riouter? Thanks
Apr 04, 2021Guru - Experienced User
I guess I'm not sure what you're asking exactly.
Are you asking what you denon connects to the router for the link speed?
Are you asking how fast your denon streams?
What are you truly asking and for what purpose?
What router do you have?
- DcmApr 04, 2021Aspirant
I havev installed a Remo+ doorbell and when i try to have it join my network I get an error thatv it can't connect. In checking the manualk it twlls me to make sure your phone is connected to 2.4GHZ and not 5GHZ.
- plemansApr 04, 2021Guru - Experienced User
what router do you have?
- ChichizolaApr 04, 2021Star
Some routers can mix 2.4 & 5 Ghz into one SSID, letting the devices choose the best. If this is your case, your IoT devices needing 2,4 Ghz will have trouble connecting. I resolved it by activating only the 2.4 Ghz Guest wireless, of course with a different SSID, conneting all my IoT devises there.
