Racko
Nov 20, 2024Follower
Question RAX120 and RAX30
I currently have an RX30 hardwired to a Spectrum modem. Speed and signal strength are not great in my 2000 sq ft home.
I also have an RX120 not being used.
Would the RX120 provide a stronger signal in my house?
Is it possible to set up my RX120 in a different part of my house, connected wirelessly to the RX30, basically used as signal booster?
As you can tell by my comments I am not technically adept.
Any help would be greatly appreciated.
Thank you.
RAX don't support extender kind of modes. However one could ethernet connect the RAX120 in AP mode and use it as a 2nd WiFi AP in the home:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985Have you swapped out the RAX30 and put in the RAX120 in it's place to see if the 120 does better wifi coverage? Maybe use the RAX30 as a 2ndary AP.
the RAX120 is a much better router than the RAX30.
Why are you using the RAX30?
Is the router centrally located?
or is it at one end of the home?
