MZavakos
Apr 28, 2020Tutor
R6300 upgrade...need suggestions
Hello, I’m asking for advice regarding upgrading from an R6300 in my home. The 6300 has been fantastic but with all the connected devices (20) and multiple streaming (3-4 devices streaming Netflix, Hu...
psychopomp123
Apr 28, 2020Luminary
Hi,
If you've got a tonne of wifi clients then I highly recommend the RAX200. Had my RAX200 for 5-6 months and its a brilliant router for wifi. Only thing i would recommend is switching off band steering in the router settings (aka 'smart connect') so that you can manually choose which of the 3 bands your wifi clients connect to.
cheers
- MZavakosApr 28, 2020TutorThank you for the feedback! Much appreciated.
Matt- plemansApr 28, 2020Guru - Experienced User
How big is your home?
what is it made of? (interior walls)
I'd also look at the mesh solutions if your home is big enough. Like orbi. They do need a bit of seperation to function properly. You might not have the same peak performance as a flagship router but they tend to have better average throughput. Which is what is more important for streaming.
