ericlo332
May 20, 2023Aspirant
R6700AX can't connect to Internet
My router model is R6700AX. I received it on April 27th and it was full new. I set my R6700AX "block all new devices" yesterday. However, I can log in the router, but it can't connect to internet a...
May 20, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
After you factory reset and setup from scratch, are you using the Nighthawk model app or wired PC and web browser to setup the router? Wired PC and web browser is recommended to setup from factory reset.
Might try this with the router disconnected from the modem then once setup, connect back to the ISP modem.
ericlo332
It had been fine since I bought and receive the router until yesterday.
Firmware version is 1.0.14.134.
I only use wired PC with web browser for setting up the router.
I do everything, and it doesn't work properly any more, same issue as my previous Netgear router.
- FURRYe38May 20, 2023Guru - Experienced User
