Mr-Chris
May 29, 2025Aspirant
R6700AX Firmware Update 1.0.19.172 Legit?
On May 20 my R6700AX reported a firmware update from 1.0.18.164 --> 1.0.19.172 but https://www.netgear.com/support/product/r6700ax/#download still reports 1.0.18.164 Just want to conf...
- May 29, 2025
NG sometimes will push new FW out to a limited amount of users. If all is good, then NG will post up on the download site.
Mr-Chris
Thank You FURRYe38 - Okay, yes, firmware installed with no problem and all systems running normally...
May 29, 2025Guru - Experienced User
Enjoy. 📡
