andrecgm's avatar
andrecgm
R6700AX Firmware V1.0.11.112 can't login into PureVPN. I can log in OK from Windows.
  • plemans's avatar
    May 16, 2022
    The R6700AX is different hardware. Meaning different firmware.
    Event expressvpn's 3rd party firmware is only for 1 version of the r6700.
    If you're wanting to use 3rd party firmware check with the maker of that vpn for the best compatible router
