RollingThunder1
Jan 09, 2026Follower
R6700AX mDNS/Bonjour not working
Updated firmware to 1.0.20.174. Internet not connected (not needed). Windows PC (fixed 192.168.16.125) wired into LAN port. Android tablets (wireless) DHCP. Primary DNS on PC set to router IP ...
Jan 13, 2026Guru - Experienced User
Not sure if this could be helpful to you:
https://community.start9.com/t/solved-mdns-on-windows-11-partially-works/1859/2
Might check for any blocks on the router or Windows and make sure firewalls or security services are not blocking anything. Disable them temporarily to check this.
Items like Armor or SPC could block if enabled on the router.
Do a search on line for mDNS/Bonjour not working for additional help resources...
