D_Day79
Sep 25, 2021Follower
R6700AX only getting 2 down and 1 up on 2.4Ghz
Purchased the R6700AX in March, have had nothing but problems with the speed on the 2.4Ghz band. Finally called support and had 2 phone calls of over 5 hours each troubleshooting the unit with no reso...
Razor512
Sep 29, 2021Prodigy
If possible try unchecking "Enable 20/40 MHz Coexistence" in the wireless settings, applying the changes, and then test the speeds again.
