Cgrower
Nov 18, 2023Follower
r6700ax router blocks my iptv app from firestick max
how do i turn off security ?
michaelkenward
Nov 18, 2023Guru - Experienced User
This is not a move that you should take willy nilly. It isn't even possible for some things.
What for? And why? You have a problem that needs fixing?
Your subject says something about a Firestick. Can you provide a bit more detail?
What is this iptv app?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Search for IPTV.
