bspngrout
May 20, 2022Aspirant
R6700AX WiFi 2.4 Connection Issue
I have a Canon MX922 printer connecting to my R6700AX router via the 2.4G Wi-Fi. Every time the printer turns on after being off for a while, it's not able to connect to my 2.4G network. It's able to...
May 20, 2022Guru - Experienced User
How is the wifi settings configured?
What security modes are you using?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz.
How is advanced Wifi settings configured?
Can AX mode on 2.4Ghz be disabled?
Contact the printers Mfr for additional help and information regarding there product as well.
- bspngroutJun 30, 2022Aspirant
Firmware V1.0.10.110
Wireless Settings:
- Enable AX: checked
2.4G:
- Enable SSID Broadcast: checked
- Channel: Auto
- Mode: Up to 600 Mbps
- Security: WPA2-Personal
5G:
- Channel: 153
- Mode: Up to 1200 Mbps
- Security Options: WPA2-Personal
Advanced Wireless Settings:
- Enable Wireless Router Radio: checked
- CTS/RTS Threshold: 2347
- Preamble Mode: Automatic
- Transmit Power Control: 100%
- Turn off wireless signal by schedule: unchecked
- Enable MU-MIMO: checked
- Disable PMF: unchecked
It took me a while to come back on this because I tried the 2.4G connection via different devices. It turns out that after I shut down my printer for a while, none of my devices, including my iPhone, my iPad and my laptop, can connect to the 2.4G network. So it doesn't seem like an issue particularly to my printer.
Because my printer is the only device that connects to 2.4G, while all the others are connected to 5G . Once it's shut down, the 2.4G is unused. It feels to me that the 2.4G would turn into some sort of sleep mode after a while. Now I force my iPhone to connect to the 2.4G so that there's always a live connection. Now the issue is gone. My printer can always connect when it's turned on.
Is it true that there's a sleep mode? If yes, is there a way to disable it or any other solution please?
- FURRYe38Jun 30, 2022Guru - Experienced User
Something to contact the printers Mfr to see about this sleep mode on there product.
Wifi on routers is always ON and broadcasting.
