manselm
Apr 27, 2023Aspirant
R6700AXS PureVPN connection says: WAN connection is not established, please check your networking!
This is a new router, I am connected to the internet and can navigate to any site. I am trying to set up the VPN Client which is included (PureVPN). I have just bougth the basic PureVPN account. ...
- Apr 28, 2023
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-modeTry option #2 first...
Apr 28, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- manselmApr 28, 2023Aspirant
Thanks for the reply, here are the replies:
Router Firmware Version V1.0.14.134
The Modem is an ARRIS DG2460
I was using a Cat 5 cable and have swapped out for a CAT 6. This did not change the results.
See attached screenshot of Router interface:
- FURRYe38Apr 28, 2023Guru - Experienced User
Couple of options,
- michaelkenwardApr 29, 2023Guru - Experienced User
Usually the easiest option to set up.
arris dg2460 bridge mode - Google Search
- manselmApr 29, 2023AspirantOK,thanks for all the replies. I have been able to eliminate the Double NAT situation and the service connected and it allowed me to verify a different VPN.
However, after a few minutes, the connection dropped. I attempted to reconnect and got the same error as above. I first confirmed that I’m still getting a public IP from the modem. So I don’t have double NAT. Please advise.
