manselm
Apr 27, 2023Aspirant
R6700AXS PureVPN connection says: WAN connection is not established, please check your networking!
This is a new router, I am connected to the internet and can navigate to any site. I am trying to set up the VPN Client which is included (PureVPN). I have just bougth the basic PureVPN account. ...
- Apr 28, 2023
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-modeTry option #2 first...
michaelkenward
Apr 29, 2023Guru - Experienced User
manselm wrote:
The Modem is an ARRIS DG2460
Usually the easiest option to set up.
arris dg2460 bridge mode - Google Search
manselm
Apr 29, 2023Aspirant
OK,thanks for all the replies. I have been able to eliminate the Double NAT situation and the service connected and it allowed me to verify a different VPN.
However, after a few minutes, the connection dropped. I attempted to reconnect and got the same error as above. I first confirmed that I’m still getting a public IP from the modem. So I don’t have double NAT. Please advise.
- michaelkenwardApr 29, 2023Guru - Experienced User
manselm wrote:
I have been able to eliminate the Double NAT situation and the service connected and it allowed me to verify a different VPN.How? What did you do? What is this different VPN?
However, after a few minutes, the connection dropped. I attempted to reconnect and got the same error as above.Those symptoms suggest that the NAT thing may still persist.
- manselmApr 29, 2023Aspirant
I set the Modem to Bridge mode.
I meant to say that now I have a public IP on the router, (previously it was a private IP generated by the modem, so double NAT shouldn't exist.
But you're right, the behavior on the NG is the same as before.
- manselmMay 01, 2023Aspirant
Hi, Thanks for your help...However I am still getting stuck setting up the PureVPN service.
My current Internet IP address is 190.219.180.42
I continue to get the same error message: WAN connection is not established, please check your networkin...etc
This time I have captured the relevant Logs:
[OpenVPN] VPN Client connection fail: WAN connection is not established, please check your networ, Monday, May 01, 2023 19:53:48
[OpenVPN] VPN Client disconnected, Monday, May 01, 2023 19:53:39
[OpenVPN] VPN Client connection fail: WAN connection is not established, please check your networ, Monday, May 01, 2023 19:53:17
[OpenVPN] VPN Client disconnected, Monday, May 01, 2023 19:53:08
[OpenVPN] VPN Client disconnected, Monday, May 01, 2023 19:53:07They do not provide a whole lot of information. One other thing...Netgear support tried to hand me off to PureVPN, but i argued that the problem was at the connection level, NOT at at the service level.
so they proceeded to ask me to set up the Dynamic DNS service, which I did. So, the logs you see above are after setting up the Dynamic DNS
- KitsapMay 01, 2023Master
Just thinking out of the box. What about IPv6? Does your ISP support IPv6? Have you enabled IPv6 in the router configuration?
Are you using a Windows computer? If yes, check under the Ethernet connection in Task Manager and it should show both an IPv4 and an IPv6 address.
I understand the desire to connect your router to the VPN service. Have you tried to connect to your VPN service from a device on your LAN running the PureVPN application?
