aldo2433
Jan 23, 2023Tutor
R6700AXS VPN
Hello, I bought this R6700AXS router to be able to use VPN (I have expressVPN) but it looks like I can only use it for PureVPN which I'm not interested in. ExpressVPN does not have firmware that ...
michaelkenward
Jan 24, 2023Guru - Experienced User
aldo2433 wrote:
ExpressVPN does not have firmware that would support this router. What can we do about this?
You'll have to ask ExpressVPN for help there.
If a device needs custom firmware, Netgear isn't going to support it and won't advise you how to "break" its routers.
- aldo2433Jan 24, 2023Tutor
thank you for replying to my post. I did ask them and they advised that it may "break" but is that true? Would it damage the router completely?
