BobbyDag
Nov 23, 2021Follower
R7900P Nighthawk® X6S AC3000 Tri-Band WiFi Router vs RAX45 Nighthawk® AX6 6-Stream AX4300 WiFi Route
I currently have a R7900P router. Costco has a
RAX45
Nighthawk® AX6 6-Stream AX4300 WiFi Router on sale.
What is the difference and should I buy the RAX45?
Thank you
1 Reply
The difference basically comes down to do you have wifi 6 devices?
If not, then I'd keep using your router. The R7900P is a pretty solid triband router and has quite a bit of capability.
Its not a slouch. So unless you have wifi 6 devices, you're not going to see much benefits to upgrading.
And even if you do upgrade, you might not see much benefits unless you're speeds you're paying your ISP for are high enough.
