ex_dilbert
Dec 12, 2019Aspirant
R8000 Nighthawk Strange browser errors with Circle enabled
Over the past few weeks I'ved started getting weird errors in my web browsers on specific website consistently. The error would appear differently in different browsers. Chrome showed ERR_CONNECTIO...
DexterJB
Dec 12, 2019NETGEAR Moderator
Hi ex_dilbert, welcome to the community! Does the issue persist if you have the laptop on a different filtering level? What about having the same filtering level on a different device?
Dexter
DexterJB
Dec 16, 2019NETGEAR Moderator
- ex_dilbertDec 20, 2019Aspirant
Hi Dexter,
Sorry for the long delay. The problem had stopped occurring for a while. Today I was able to test it on another laptop and get the same error using the same filter and a different filtering level. Only when I turn off Circle does the error disappear. This is truly a strange occurrence because it seems so random.
- DexterJBDec 22, 2019NETGEAR Moderator
Hi ex_dilbert, have you tried resetting the router back to factory settings? If not, this something you can try. You can backup your router settings as well as your Circle settings and have them restored later. The links below may help.
https://kb.netgear.com/000031537/
https://kb.netgear.com/000031536/
Dexter
