justinto
Oct 02, 2021Aspirant
R9000 Losing Wired Ehternet Ports - AGAIN
I have the Nighthawk R9000 modem and when I first got it at the beginning of 2020, I was having problems losing the wired ethernet ports every day and I had to reboot the modem and the router to rest...
- Oct 03, 2021
When the newest firmware upgrade failed again after a few hours, I took your advice and loaded the previous version. Looking at the version dates, it made sense. I started having problems as soon as the newest version was loaded. So far, so good. Thank you.
I am surprised how a company like Netgear can update equipment with faulty firmware.
justinto
Thank you for the response. Do you know how to downgrade the update? I know how to turn off the auto updates, but if I recall with a factory reset and new install, it looks for a new update.
Oct 02, 2021Guru - Experienced User
Simply download it from the support site and extract it.
Then follow the manual update process but use the older firmware instead of newer.
https://www.netgear.com/support/product/r9000
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- justintoOct 02, 2021Aspirant
Thank you. I will try it and let you know if it worked.
- justintoOct 03, 2021Aspirant
- Razor512Oct 03, 2021Prodigy
In such as case, since wired connectivity is heavily tested, I wonder, with any of the more recent updates, were any settings relating to power saving functions on Ethernet, such as Green Ethernet and other related functions changed? Sometimes areas like that can cause issues with some cables, especially extremely slim cables.
