cuke2u
Aug 19, 2023Aspirant
Random Loss of Connections..
My router is randomly and intermittently turning off it's wired and WiFi connections, which means every device connected loses it's connection. It occurred several times yesterday and sometimes occu...
- Aug 20, 2023
The modem is a tp link TD-W9970 in bridge mode, but it has been 100% stable since I setup the netgear with it until recently, we're talking months if not years.
Anyway I took a look at the netgear settings and it looks like these disconnects might have coincided with some settings I put into the ipv6 page. So I've reset it to off for the moment and will test.
My bad if this issue was self inflicted...
michaelkenward
Aug 19, 2023Guru - Experienced User
Did this just start happening? Does the modem keep its connection? Any clues from the router's LEDs?
What firmware version do you have on the device?
A number is more useful than "the latest". There can be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
