Harley55
Nov 28, 2021Guide
Rax 120-100NAS Reboot Problem
I have a RAX120-100NAS running firmware 1.2.3.28. I noticed it reboots servel times a day. What's astable firmware to use or does anyone have a solution.
- Nov 29, 2021
I checked the reviews of Netgear routes 120, 200, 500 and they all have a rebooting problem. Thanks for your help
Nov 28, 2021Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Harley55
Nov 28, 2021Guide
Spectrum EU2251 Firmware 2.76.2
Channels are set to Auto
Near by Spectrum nothing close by
Reset was done. Rebooted after setup.
- FURRYe38Nov 28, 2021Guru - Experienced User
Does the router reboot if the WAN cable is not connected to the modem?
Might try downgrading FW to v24 and see if this continues or not. IF so, I would presume the router is faulty.
- Harley55Nov 28, 2021Guide
Right now I'm waiting to see if any changes happen after I did a total system reboot after everything was setup. It only reboots a few times a day since I installed it yesterday. I also have a Netgear R7000 that acted the same way. We found a older verison of the firmware that solved the problem. If the reboot doesn't solve the problem then I'll try the channels.
- Harley55Nov 29, 2021Guide
So far since I changed the 2.4 GHz to channel 1 it's been 12 hours and no reboot.
