Harley55
Nov 28, 2021Guide
Rax 120-100NAS Reboot Problem
I have a RAX120-100NAS running firmware 1.2.3.28. I noticed it reboots servel times a day. What's astable firmware to use or does anyone have a solution.
- Nov 29, 2021
I checked the reviews of Netgear routes 120, 200, 500 and they all have a rebooting problem. Thanks for your help
Harley55
Nov 28, 2021Guide
Right now I'm waiting to see if any changes happen after I did a total system reboot after everything was setup. It only reboots a few times a day since I installed it yesterday. I also have a Netgear R7000 that acted the same way. We found a older verison of the firmware that solved the problem. If the reboot doesn't solve the problem then I'll try the channels.
Harley55
Nov 29, 2021Guide
So far since I changed the 2.4 GHz to channel 1 it's been 12 hours and no reboot.
- FURRYe38Nov 29, 2021Guru - Experienced User
Good to hear. Hopefully this will be the fix. Possible that the other channel is congested with nieghboring signals and causing problems.
Please mark your thread as solved so others will know.
Enjoy.- Harley55Nov 29, 2021Guide
Is there a way to see in the router or else where to see the channels being used and by who?
Most any wifi scanning or analytical app has features to see what wifi signals are being broadcast and what channesl they use. Most apps work best on pads vs phones.
