Harley55
Nov 28, 2021Guide
Rax 120-100NAS Reboot Problem
I have a RAX120-100NAS running firmware 1.2.3.28. I noticed it reboots servel times a day. What's astable firmware to use or does anyone have a solution.
- Nov 29, 2021
I checked the reviews of Netgear routes 120, 200, 500 and they all have a rebooting problem. Thanks for your help
Harley55
Dec 22, 2021Guide
Harley55 wrote:I have a RAX120-100NAS running firmware 1.2.3.28. I noticed it reboots servel times a day. What's astable firmware to use or does anyone have a solution.
- derekcannadyDec 23, 2021Guide
I am also having the same issues, and have already had Netgear replace the router once. The replacement does the same thing. The router reboots frequently soemtimes every 30 mionutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to lessen the issue is by turning off 2.4 Ghz WMM services. Unfortunately my 2.4 Ghz devices pay the price for that with slower throughput. I can't even view some security camera streams any longer because the bandwidth is so poor. I am within the time period to return the router. I'm hesitatnt to purchase the RAX200 because of the same issue. I may have to try another brand after 10 years of using NG.
- FURRYe38Dec 23, 2021Guru - Experienced User
Let us know if you can get the OP to post how they solved it...
