Retired_Member
Nov 26, 2021RAX-120: android devices fail to obtain IP address
Hello, I Just purchased the RAX-120, set it up, all my home devices connected just fine. I went to device manager, renamed a few (including the device which now fails to connect ), a hour later th...
Nov 27, 2021Guru - Experienced User
