Redflagdan
Aug 29, 2019Tutor
RAX 120 authentication issues
For some reason after a period of several hours any device that trys to logon into my wireless system gets an authenication error, the password is invalid. My firmware is V1.0.1.90. I have tried t...
Kahless
Nov 07, 2019Aspirant
Not sure if my issue is exactly this. Just this past weekend the network started to have issues. The laptop connected to the router via Ethernet is able to maintain an Internet connection. However, all wireless devices (Apple TV, Sony Bravia 930, HP laptop, iPhones, iPads, Nest) lose Internet access. The devices still show as being connected to the network with full signal strength, but are not able to access Internet content. I am also sometimes unable to connect to the router through the Nighthawk app even though the device shows as being on connected to the network. When I try to access the router inteface through a browser it will throw up a login screen every 30 seconds to a minute and often reject the username and password (even though they are correct and work a few seconds later) and the logs will show a failed authentication. My laptop will also throw an error in every browser saying something like your connection is not private NET::ERR_CERT_COMMON_NAME_INVALID for google.com but then go on to connect after 30-45 seconds.
We have had the ISP check the cable modem and all is fine. So, this seems to be some issue with the router. I've unplugged it and let it sit for 30 seconds or so but that doesn't seem to fix anything. I've not tried a reset or to turn off SmartConnect or AX as of yet. It is running on .90 and I'm not sure when .90 wasa installed on the router.
2dk2c
Nov 09, 2019Aspirant
Router Firmware Version V1.0.1.100
Guest account will not accept any secured mode and any password is wrong.
wpa2, wpa3, nothing works except "security options:none"
I've had the router most of this year but only today did I need a guest-access account.
I want you to notice it's the latest firmware, and rebooting the router/recycling the power do not work.
Smart-connect is not-checked (it's off).
Is there any bromide I've missed?
- Christian_RNov 12, 2019NETGEAR Employee Retired
Hello 2dk2c,
For more info on setting up the guest WiFi network, please refer to page 78 of the user manual:
http://www.downloads.netgear.com/files/GDC/RAX120/RAX120_UM_EN.pdf
Christian
- 2dk2cNov 13, 2019Aspirant
Christian_R wrote:Hello 2dk2c,
Christian
The very next page says how to set up "none", "wpa2", etc (I'm quoting step 6)
only "None" works on my router, it will refuse all passwords on a guest account.
- KillhippieNov 14, 2019Prodigy
Just to say I have a guest account with password and it works fine using WPA2 AES, a factory reset is probably whats needed here.
