idaho_lewis
Dec 04, 2020Aspirant
RAX 120 Auto Firmware Update - I Disagree does not work
I had firmware version V1.0.1.122 installed for several months, and regularly used enable the telnet option from the /debug.htm page to access the OS. The router has been working perfectly, but deci...
Newfiedrool
Dec 07, 2020Virtuoso
Why are you running such old software which is open to security threats?
I have no issues apart from a slight log issue with the latest firmware and considering it's very stable and does what it's intended to do I would say stick with the latest build.
- idaho_lewisDec 07, 2020Aspirant
As I mentioned, I want the ability to use telnet to log into the OS.
- NewfiedroolDec 07, 2020Virtuoso
Well I guess if it's updating and you can't stop it then you either have to keep downgrading when you want to telnet or you live with the fact you have the latest firmware with all the security and other bit and bobs they have added behind the scenes.
