RAX120USER
May 26, 2020Tutor
RAX 120 disconnected from internet
Hi All, Hopefully that I am not the only person who has this issue. I use an NBN FTTP fibre network from my ISP, and the NBN box (the fibre network connected to my unit. In Australia, it is call...
Christian_R
Jun 02, 2020NETGEAR Employee Retired
Hello Nighthawk AX Community,
Have you had a chance to perform a factory reset after the recent firmware update?
Christian
- DarkHopliteJun 02, 2020Tutor
I have reset the router and did reinstalled the latest firmware, I will report back on Friday 5th June with an update.
kind regards
Dark
- DarkHopliteJun 05, 2020Tutor
Router appears to be stable after fresh install. However Lan speeds seem capped at around 350mbs and wifi around 500mbs.
I have a 1gig internet speed plan.
- RAX120USERJun 05, 2020Tutor
please wait for about at least 3 days before the reporting, because usually it takes about 1 day or 2 to disconnect from internet.
hopefully that it just like what you said which is that a reset can be helpful with the latest version.
For me, i flash the 118 version back, and all good till now.
