RAX120USER
May 26, 2020Tutor
RAX 120 disconnected from internet
Hi All, Hopefully that I am not the only person who has this issue. I use an NBN FTTP fibre network from my ISP, and the NBN box (the fibre network connected to my unit. In Australia, it is call...
DarkHoplite
Jun 02, 2020Tutor
I have reset the router and did reinstalled the latest firmware, I will report back on Friday 5th June with an update.
kind regards
Dark
DarkHoplite
Jun 05, 2020Tutor
Router appears to be stable after fresh install. However Lan speeds seem capped at around 350mbs and wifi around 500mbs.
I have a 1gig internet speed plan.
- RAX120USERJun 05, 2020Tutor
please wait for about at least 3 days before the reporting, because usually it takes about 1 day or 2 to disconnect from internet.
hopefully that it just like what you said which is that a reset can be helpful with the latest version.
For me, i flash the 118 version back, and all good till now.
