MMargolis
Mar 15, 2020Tutor
RAX 120 firmware update not seen
So I received an email notifying me of a router firmware update to version v1.0.0.1.118.: I am in fact running v1.0.0.1.114 I quote, " We've Enhanced Your Product's Security. Please Update ...
Sal_R
Mar 16, 2020Aspirant
Im having the same issue with the update not showing and im assuming this update is to fix the issue with the router randomly disconntecting from devices. Which is starting to become very annoying. The only fix I have found so far is to reboot the router everyday.
- NewfiedroolMar 17, 2020Virtuoso
It's a hot fix so will not be pushed.
https://www.netgear.com/support/product/RAX120.aspx
download and install via web UI.
- Sal_RMar 17, 2020AspirantIs there a timeline of when an actual update will be released. Non beta?
No
- MMargolisMar 17, 2020Tutor
Newfiedrool wrote:It's a hot fix so will not be pushed.
If it is a hotfix and needs to be downloaded, why would they push an Email telling us to use the app update and install?
Probably an error on their part.
- GkalydyMar 18, 2020AspirantI am having issues daily with my router disconnecting only certain devices and not all. I have the hot fix beta version .118 loaded and it does not fix this issue. Anyone having the same problem and can tell me how to resolve? The app shows the internet as disconnected but when you run the speed test the internet is found.
- MMargolisMar 18, 2020TutorThe hotfix has acctually made my issue worse... I now need to see if I can fin ver. 114 cause 118bis horrific.
- NewfiedroolMar 18, 2020Virtuoso
Try reinstalling it again and do a reset.
