eastern_bloc_gu
Mar 25, 2021Tutor
RAX 120 Homekit issues
Hi All, I changed from an Orbi RAC50 to a Nighthawk RAX120 router to upgrade my home network and since the upgrade I contantly have issues with my Homekit smart devices. I have a big selection of...
thehypnootoad
Mar 25, 2021Luminary
3 options if they connect once try reserve ip. 2nd option is buy a ac extender for them to connect through. 3rd is roll back to .136 via wired and pin reset afterwards. Try these the newest firmware is troublesome.
- eastern_bloc_guMar 25, 2021Tutor
Meanwhile I realized I am a total mess, I have the RAX200 and not the RAX120...:D Do you know which FW is there the stable one? The rest of the other 2 options is also valid?
- thehypnootoadMar 25, 2021LuminaryNot to familiar with rax 200 firmware sorry best asking on fresh post best updating wired and using pinhole reset afterwards helps fix alot of problems.
