thehypnootoad
Feb 17, 2021Luminary
Rax 120 issue
Everytime i make a change on the router to do with wifi or internet the change bar does it but the internet stops working and can only be sorted by turning on and off again is this a bug running lates...
No1Mportnt
Does it restart after the progress bar gets to the end? Sometimes it does take a few seconds after the progress bar gets to the end.
- thehypnootoadFeb 17, 2021LuminaryI leave it till bar finishes then it times out I normally leave it upto 10 minutes all lights are on but no connection I manually reboot it.
