thehypnootoad
Feb 17, 2021Luminary
Rax 120 issue
Everytime i make a change on the router to do with wifi or internet the change bar does it but the internet stops working and can only be sorted by turning on and off again is this a bug running lates...
Feb 18, 2021Guru - Experienced User
What firmware version is it on?
What modem/gateway is it connected to?
thehypnootoad
Feb 18, 2021Luminary
I believe its version Support
RAX120 Firmware Version 1.2.0.16
Modem is huawei hg612b unlocked to see stats
- jweaver4475Feb 18, 2021Aspirant
Which settings in the router are you changing?
Are you connected wirelessly or with a wired connection when making these changes?
- plemansFeb 18, 2021Guru - Experienced User
The huawei hg612b has its own integrated modem. it can put you in a double nat.
do you have the netgear's ip address entered in the huawei's dmz?
or the huawei in passthrough mode?
or you can try the netgear in access point mode and let the huawei control the routing.
- thehypnootoadFeb 18, 2021Luminary
I have it in pass through but think I might do what you said with access point thank you for help.
