Jaimem91
Jul 10, 2021Tutor
RAX 120 Keeps going offline but wifi still works?
Pretty much the router states its offline and direct ports from router through my pc lose connection and doesnt work. But interestingly while the router says its offline all my wifi device connection...
Jul 11, 2021Guru - Experienced User
What actual modem/gateway do you have?
Jaimem91
Jul 11, 2021Tutor
The modem is NETGEAR - Nighthawk 32 x 8 DOCSIS 3.1 Cable Modem
Model:CM2000-100NAS
I have xfinity internet as well.
Model:CM2000-100NAS
- plemansJul 11, 2021Guru - Experienced User
Try this.
1. factory reset the RAX.
2. power off both the RAX and the CM2000
3. disconnect everything from both. even the coax from the cm2000
4. wait 2 minutes.
5. connect coax back to cm2000, and then power it on. wait 2 minutes.
6. Connect lan port on cm2000 to wan port on the RAX. (don't uses the 2.5g port for now)
7. power the rax on and give it 2 minutes. then set it up.
8. try it for a period. Don't use the 2.5g port
Reason I say don't use the 2.5g port right now is I've seen sketchy cables cause intermittent connections between 2.5g ports that work fine on a 1gig port.
If it stays stable then try using the 2.5g port. Just make sure to use a high quality cable.
