danielshaw007
Feb 10, 2021Aspirant
Rax 120 no 5ghz..
Hi all Just installed my rax 120 enabled smart connect so the router decides what uses 2.4 or 5ghz etc I have noticed EVERYTHING is on the 2.4ghz and I checked with an wifi analyser app that ...
danielshaw007
edit: noticed red light in the routers web interface on the 5ghz so its not actually on but the option to enable it is faded.
Christian_R
Feb 15, 2021NETGEAR Employee Retired
Hello danielshaw007,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
