gfs10
Jan 15, 2021Follower
RAX 120 problem communicating with Samsung 5g phone
I have a RAX120 running wpa2. the router communicates with all my devices, (even though i have found the range is really bad.) except one. if i connect my phone to the 5ghz. it connects but apps do ...
Newfiedrool
Jan 16, 2021Virtuoso
As you have 2 posts and seem to have an issue with both AX, WiFi range and devices I wire up a pc or Mac and download the latest update from the support page.
Do a manual update over the top, then reset using the rear pin hole method.
Set the router up as new, do not use a saved config profile.
Test.
