Raptorweb1
Sep 05, 2022Aspirant
RAX 120 QOS
For an upgrade this seems like a step backwards. My WiFi 5 Nighthawk let me limit both upload and download speeds and this only lets me limit upload which still leaves alot of latency.
microchip8
Sep 06, 2022Master
Not much you can do about it, and hope it gets implemented in a future firmware version.
PS: if your line is fast enough (300-1000 Mbps) your shouldn't be using QoS unless you have a very good reason.
- Raptorweb1Sep 06, 2022Aspirant
My line is 300mb, but letting the download run unchecked still causes latency. Hooking up my old router runs online FPS better than new one. Just seems sad that this is a thing with the newer routers.
- michaelkenwardSep 07, 2022Guru - Experienced User
Enabling QoS, as in your subject, is not advised with an Internet speed of 300 Mbps.
That is fast enough for just about everything you do and can slow down the router because it requires processing power.
