Mandrew373
Sep 05, 2024Aspirant
RAX 120 Slow Download speeds
I have been having an ongoing issue with download speeds on my RAX 120. I factory reset the modem already, firmware is up to date, QOS is turned off. For about a day I got normal download speeds(usual...
- Sep 05, 2024Welp, I feel like an idiot now. I replaced the Ethernet cable that ran from the modem to the router and my speeds are running consistently around 660mbps. Been that way for a few hours now.
Sep 05, 2024Guru - Experienced User
What channel configurations are currently set on the router?
Is Smart Connect enabled or disabled?
Please detail the current settings seen under Advanced tab/Advanced Settings/Wireless Settings.
They have inexpensive USB to ethernet adapters. I have couple I use on my Mac Book Pro
Also since the TV only seems to support 100Mpbs on the connection, it will never see speeds past this.
Mandrew373
