SSGGBLUE
Jan 28, 2020Aspirant
Rax 120 slow wifi speed
Need some adivse on to what causeing the rax-120 to have slow wifi speed. I got the gig-speed with comcast. my modem is the CM1000. im getting 950mbps. on 5g wifi testing it on mutiple devices im onl...
Christian_R
Jan 30, 2020NETGEAR Employee Retired
Hi SSGGBLUE,
You may need to try changing the WiFi channels on the bands. You may also try disabling smart connect and/or AX WiFi to see if there are any improvements.
Christian
- J-C-SJan 30, 2020AspirantI’ve been having the same problem with the same router. I’ve tried resetting it, disabling ax, removing or adjusting QoS rules, changing channels and it will still throttle after some time. I have to disconnect and reconnect my pc to WiFi and it will work fine again. Strangely, hard wired won’t do it, only on WiFi. Hoping this gets fixed with new firmware
