Mask0mimi
Apr 11, 2023Aspirant
RAX 120 V1 Firmware Version 1.28.40 constantly powering off and rebooting multiple times
Going through my wit's end. My router has been powering on and off multiple times a day as of the past few days. Have tried confirming it is on the latest firmware, have factory reset it, tried c...
Mask0mimi
Ah gotcha, thanks for clarifying!
I'll try setting the power transmit% to 25% and let you know how it goes 🙂
I've tried the manual channels mentioned periodically over time but haven't seen a difference here, to be honest.
I have enabled Smart Connect previously but found it was interfering with the performance of down/up speeds I was getting unfortunately. Do you recommend re-enabling this to combat the power issues being reported?
Apr 11, 2023Guru - Experienced User
Lets try the cable and transmit power first.
I would set manual channels as well.
I might set 40Mhz only channel width as well.
