Mask0mimi
Apr 11, 2023Aspirant
RAX 120 V1 Firmware Version 1.28.40 constantly powering off and rebooting multiple times
Going through my wit's end. My router has been powering on and off multiple times a day as of the past few days. Have tried confirming it is on the latest firmware, have factory reset it, tried c...
Mask0mimi
Hey FURRYe38 - transmit power failed and setting the manual channels for each 2.4 and 5G bands failed to resolve the issue unfortunately (lasted two hours though!)
To confirm I am using the following cable now which looks to be STP supported: https://www.amazon.ca/gp/product/B07YQQ8BG5/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
How does one set 40mHz only channel width? I only see the option for 20.40 MHz Coexistence. Let me know if I should try anything else.
Apr 11, 2023Guru - Experienced User
Uncheckmark the check box next to 20/40Mhz.
Can try disabling WMM feature I guess as well...
- Mask0mimiApr 11, 2023Aspirant
Yup can confirm the checkmark next to 20/40mhz was already disabled.
Have tried disabling WMM previously but have not seen this resolve the issue either unfortunately 😞
Anything else you'd recommend trying out? - FURRYe38Apr 11, 2023Guru - Experienced User
Running out of ideas.
Only thing I would try would be to load FW using a wired PC and web browser on to the router. Then power cycle the router OFF for 30 seconds then back ON. Factory reset and setup from scratch using a web browser. Don't enable any features. Set single SSID name and PW with smart connect enabled. Manual channel 1, 40 and 149.See if this happens more.
Any chance you have a neighbor, friend or family member that you could take the router to to see if the problem follows? Would be telling...
Sorry FURRYe38 haha didn't mean to stump you!
To confirm, should I be uploading the same 1.2.8.40 firmware using a wired PC? I did try this last night and performing a factory reset, before writing in today but would like to confirm what constitutes as "Features"? Should I not be using the Multi-Gig port as well as this counts as a feature too?
For the single SSID, should this be on the 2.4GhZ band or 5GhZ or does it not matter which one I choose?
I have tried using the router over at a friend's place too but no luck unfortunately 😕 - at this point assuming this is a hardware issue and I'm just due for an upgrade.
Ya try the 1Gb WAN port.
Doesn't matter, just enable Smart Connect
Ok, if you tried the router at a different location and problem follows, the router maybe just plain faulty and needs replacing.
Last resort you could try this and see. No guarantees:
