termit
Feb 25, 2020Aspirant
RAX 120 Why does not support ReadyShare Printer
I need a network printer, features on the RAX 120 Does a router cost $ 500 and is it without the functions of a network printer?
To work through a USB port
- Christian_RNETGEAR Employee Retired
Hello termit,
What firmware version is your router currently on? Have you tried reverting to previous firmware versions to see if the issue persists?
Thanks,
Christian - termitAspirant
Hello
I previously had the firmware version 108 it did not work updated to version 118 and there is also not zarabotolo
the router does not see a printer connected via usb- Christian_RNETGEAR Employee Retired
Hello termit,
Thanks for confirming. ReadyShare Printer has been a feature request by many others. I will forward this to our products team for further consideration. However, are you able to register your RAX120 to ReadyCloud as I noticed you commented in a previous post regarding this.
Thanks,
Christian- GaryLin3321Aspirant
I also need this feature, please support as soon as possible.
Thanks!
- termitAspirant
In firmware 118, the ReadyCLOUD feature was fixed, and now everything works
